Psp To Laptop Via Usb Cable??
Discussion in 'Playstation Forums' started by breakersrevenge, Sep 22, 2005.
  1. breakersrevenge
    breakersrevenge
    Jan 9, 2005
    2,178
    Draycott, Derbyshire
    +228
    Trying to link my Jap PSP to my laptop but when I connect the two via a usb cable, its showing 'device not recognized'
    Any ideas on how to solve this so it works or do I need software???
    Thanks in advance!
  2. chrislad
    chrislad
    May 6, 2005
    5,642
    83
    Rep. of Ireland
    +141
    You need Windows XP or 2000, updated to the latest Service Pack as far as I know. I know mine worked right away, and it's a JAP PSP.
  3. Forestred
    Forestred
    Oct 2, 2003
    297
    Norwich
    +6
    I had the same problem for a bit but it seemed to sort itself out, I did change the cable as I was using a USB 1 cable and the problem has not come back (touch wood).
    I don't think it was the cable causing the problem but if yours is a cheapy then I would recomment buying a USB 2.0 stamped one. I am using Windows XP with service pack 2 FYI.
    Another thing that did seem to make it work (although again I can't promise that this will solve the problem) was plugging in the power lead before connecting the USB cable.
    I don't know what actually solved the problem but these seemed to help - don't shoot me down if they don't work for you.
    Regards
    FR
  4. breakersrevenge
    breakersrevenge
    Jan 9, 2005
    2,178
    +228
    Thanks guys, will give it a try!
  5. Forestred
    Forestred
    Oct 2, 2003
    297
    Norwich
    +6
    No problems, let us know how you get on and good luck with it.
  6. breakersrevenge
    breakersrevenge
    Jan 9, 2005
    2,178
    +228
    No Luck!!
    Getting a message
    ''One of the USB devices attached to this computer has malfunctioned, and windows does not recognize it''
    any other ideas?
  7. scoo
    scoo
    Jul 22, 2005
    169
    +6
    Try connecting it to another pc. This should tell you if it is a problem with your laptop, or the cable/psp.
  8. jezzah
    jezzah
    Sep 7, 2005
    Farnborough
    This might seem obvious but you haven't mentioned selecting the USB Connection on the PSP after attaching the cable to your computer. The computer should then recognise the PSP.
