Can I connect to internet via my computer - ntl broadband, by using a Cable & Wireless 802.11g LAN Mini USB Adapter. will this allow me to play multiplayer games and surf the net? If so, how do i go about setting this connection up? I am a newbie.
you need a wireless router mate to get it to work. i've got mine connected to a belkin 54g router/modem via wireless. just set the router to open (or no encription) and in the psp menu do the following:
network settings>infrastructure mode>new connection(name it when prompted)>scan>then choose your access point>wlan security setting set to none>address settings set to easy>then just press the O button to save.
Simple as that and you can browse straight away
If you are using Windows XP you should be able to set you PC up as a 'router' using Windows 'Internet Connection Sharing'. If you do a search on the net you should find lots of user guides on how to go about setting this up. Your PC will then allocated a TCP/IP address to any computers connecting to it via wireless.
