PSP Problem
Discussion in 'Playstation Forums' started by zub316, Jun 6, 2008.
  1. zub316
    zub316
    Jun 6, 2008
    190
    +3
    Hi Guys
    My psp has recently stopped chargin. the battery works however the charger does not work.
    as i am looking to sell it to get some money for the ps3 what would you recommend for me to do
  2. xist
    xist
    Feb 8, 2007
    496
    +56
    How do you know that the battery isn't at fault? Have you tried another to see if the AC adapter truly is kaput? If that is the case however, surely the simplest option would be to buy a replacement? Will the PSP not play from the mains without a battery inserted?
