PSP on BT voyager 2100 wireless
Discussion in 'Playstation Forums' started by Darko, Aug 13, 2005.
  1. Darko
    Darko
    Apr 13, 2005
    3,710
    Caterham on the hill Surrey
    +175
    I have preordered my psp for day of release and want to get ahead of the game so what I want to know is will I be able to access the web via the bt voyager and if so how is it done, Will the psp recognise the modem and will it ask for the ssid automatically or do I have to set this up on the psp
    I know I am jumping the gun abit but I want all the answers before I get it.
    Cheers Darko
  2. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    I think all you need to do is make sure the wireless settings are appropriate, make a note of your wpa key if you have one and make a note of the ssid and take it from there.
    It is very straightforward to set up on the psp, I had no problems with my netgear wireless router
  3. Darko
    Darko
    Apr 13, 2005
    3,710
    +175
    Cool I figured it would be pretty straight forward I am just covering all bases
    you know how it is.
    Cheers Darko
  4. Darko
    Darko
    Apr 13, 2005
    3,710
    +175
    another dumb question !!!
    The BT Voyager 2100 Wireless is 802.11g and I am not sure if it is also 802.11b compatable has anyone got any knowledge on this
    Cheers Darko
  5. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,287
    +146
    Ive got a 3com wireless router in my house that I use for the works laptop, and my PSP detected it itself with no worrys.
  6. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,416
    North East Scotland
    +65
    That's not a dumb question for the likes of me...
    Yes, it is 802.11b compatible. I have got the 2100 Voyager and my PSP communicates with it no problems.
  7. Darko
    Darko
    Apr 13, 2005
    3,710
    +175
    cool did you have any problems setting the psp up with it?
  8. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,416
    North East Scotland
    +65
    No, as earlier poster said, just have to enter the SSID (wireless network name, for example BTVOYAGER2100-DE).
    Easy as 1-2-3.
    Good luck and just ask if you have any more questions.
  9. Ger
    Ger
    Jun 9, 2003
    1,620
    Ireland
    +84
    What about setting up WEP encryption?? I still haven't had any luck with it and the PSP (I have a Belkin router, but I assume the procedure would be the same for any router). Does anyone have a guide for setting this up??
  10. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,416
    North East Scotland
    +65
    I don't recall having to do anything about WEP encryption. :confused:
    I will have a look tonight (I have the BT Voyager, though, the Belkin may be different).
  11. Darko
    Darko
    Apr 13, 2005
    3,710
    +175
    Cheers bud
