PSP Movie Converter
Discussion in 'Playstation Forums' started by hughesy, Apr 12, 2005.
  1. hughesy
    hughesy
    Jan 22, 2005
    846
    Irish in Oz
    +13
    Hi guys,
    Anyone know where to get the movie converter software for the psp? :confused: ? :confused: ?
    Hughesy
  2. pmwhelan
    pmwhelan
    Jan 6, 2005
    959
    Dublin 1, Ireland
    +45
  3. hughesy
    hughesy
    Jan 22, 2005
    846
    Irish in Oz
    +13
    Will do, thanks
  4. hughesy
    hughesy
    Jan 22, 2005
    846
    Irish in Oz
    +13
  5. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    34,361
    Bristol
    +7,932
    Been converting DVDs to PSP MPG4 files since January, very easy to do and with PSP Video 9 it is mad even easier as it will create all the directories you need on the memory stick and it has good options.
  6. Rock_500
    Rock_500
    Used Video 9 last night and it works well the only problem is i need some way of joining the files together it create's, or joining the dvd VTS files after using dvdshrink. Anybody got any idea's ?
  7. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    34,361
    Bristol
    +7,932
    Can I ask why are you using DVDShrink? as it really is just for converting DVD9s so they are small enough to fit onto a DVD5.
    If you want to extract a film from a DVD then I recommend using DVD Decrypter. It is simple to use and you can set it so it outputs the film as a single .vob file which you can then just load straight into PSP Video 9.
  8. Rock_500
    Rock_500
    I use dvd decypter, but did not realise you can output a single vob :) i use dvdshrink as its easy to strip out the menus and just backup the main movie file. I guess i could use decrypter on the dvdshrink files to get a single vob maybe.
  9. dr_loss
    dr_loss
    have a look at the downloads section of my site, theres loads of progs for movie conversion out there now
    www.ballofodd.co.uk/psp/
  10. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,339
    +850
    What happened to your website mate? It looks a state! :eek:
    I remember it a couple of months ago, much better! :thumbsup:
  11. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    34,361
    Bristol
    +7,932
    You can use DVD Shrink in re-author mode to remove the menus but why not just use DVD Decrypter in IFO mode to select just the film and extract it that way, seems alot easier to me.
    Also, to make it output a single .vob file go into Tools/Settings and under IFO mode select None in the drop down box next to File Splitting, this will result in a single .vob file which you can just load into 3GP or PSP Video 9.
  12. Rock_500
    Rock_500
    Indiana, just use to using dvd shrink i guess, i will have a play again with decrypter, but i am looking for a easy solution so new users on a psp can put dvd's easily onto them.
    Dr_loss had a look but could not find what i was looking for, btw can you add my site to your links page ?
    If i do find a simple program to combine vob files i will post here.
  13. dr_loss
    dr_loss
    has become a bit of a burden keeping it up and running, and theres loads more competition out there now.
    done some updates tonight so maybe its working a bit better?
    _________________________________________________
    www.ballofodd.co.uk - sadly not as good as it used to be?
  14. Rock_500
    Rock_500
    ok, found a easy tool for joining vob files here. Simply join the vob files, then run psp video 9 to convert the single vob to mpg4 for the psp.
  15. figoagogo
    figoagogo
    Mar 29, 2005
    8,162
    +575
    How do you rip to a single VOB? I too was using DVD Shrink - but now trying Decrypter, not sure how to extract to one VOB
  16. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    34,361
    Bristol
    +7,932
    I posted how to extract to a single .vob file above but here it is again...
    To make it output a single .vob file go into Tools/Settings and under IFO mode select None in the drop down box next to File Splitting, this will result in a single .vob file be created.
  17. figoagogo
    figoagogo
    Mar 29, 2005
    8,162
    +575
    :lesson:
    :oops:
    THANKS!
    :lesson:
    EDIT: Why are files split in the first place?
  18. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    34,361
    Bristol
    +7,932
    It has something to do with DVD players not being able to read files bigger than 1Gb in size, trust me if you burn a 4Gb .vob file to a dvdr and try to play it back it will get to about 20mins into the file then it will just stop, sure someone else will be able to give more detailed info.
