PSP Memory Cards
Discussion in 'Playstation Forums' started by slowen, Jan 24, 2005.
  1. slowen
    slowen
    Jan 16, 2005
    208
    16
    Does anyone know of any good companies that sell cheaply priced memory cards for the PSP. I am looking for either a 512mb or 1GB card
    What is the difference between:
    Memory stick duo and the memory stick pro?
  2. DEV
    DEV
    Nov 11, 2004
    72
    +5
    The difference between memory stick pro and duo is its size. The pro is longer and will not fit in the PSP. However to confuse things you can get a duo pro. The duo pro memory stick has faster memory than a standard duo. If you scan the web you should be able to get a Sandisk Memory Stick Pro Duo 512mb for about £50 or Ebay for Sony one. The official ones are more expensive.
  3. slowen
    slowen
    Jan 16, 2005
    208
    16
    Thanks for info
    you say the pro does not fit the psp, but is this the same case with the pro duo?
  4. petecowie
    petecowie
    R.I.P.
    Sep 3, 2003
    884
    2
    Essex
    +42
    I have a 512Mb Pro Duo in my machine bought from www.digimem.biz for £47 inc vat and delivery they also do a 1Gb for £97. Delivery was in less than a week.
  5. slowen
    slowen
    Jan 16, 2005
    208
    16
    Thanks, might give them a try
    have you used your card for movies and mp3's yet? what is the quality
  6. petecowie
    petecowie
    R.I.P.
    Sep 3, 2003
    884
    2
    Essex
    +42
    Yes have used mem card for both MP3 and Movies very impressed with movie quality, great resolution and no stuttering. Files are a bit larger than I would like, I currently have 1-2 Albums and 13 Music Vids (70mins?) and my mem card is full. Don't think you could go for a whole movie without encoding at a non impressive resolution though. I am happy for someone to tell em I'm wrong on this......
  7. eatonluke
    eatonluke
    Jan 2, 2005
    59
    goto www,computerwebstore.co.uk for a memory stick duo pro 1gb for £88 inc post
  8. eatonluke
    eatonluke
    Jan 2, 2005
    59
  9. eatonluke
    eatonluke
    Jan 2, 2005
    59
