PSP Grips
Discussion in 'Playstation Forums' started by h0l1yw0od, Nov 6, 2005.
  1. h0l1yw0od
    h0l1yw0od
    Nov 16, 2000
    477
    +13
    I'm thinking of getting a set of grips for my PSP as i find using the nub to be quite painful on my thumb after a while. I figure the grips would give me a better hold and save the cramp in my poor thumby.
    Can anyone recommend any and where to get them? I've forund some here but though i'd ask anyway.PSP Tree - Grips
    Thanks.
  2. alchemystical
    alchemystical
    Oct 3, 2005
    2,900
    +831
    Radica grips are the best:
    [​IMG]
  3. Stinja
    Stinja
    Aug 13, 2003
    12,846
    163
    +4,204
    Not sure about the case it comes with. Has anyone tried other 3rd party grips? Did h0l1yw0od ever get some?
    I was looking at these myself, for much the same reasons: Brando Flexible
  4. hot-fuzz
    hot-fuzz
    Dec 13, 2005
    6,086
    Hampshire/Surrey, UK
    +593
    For £5 who cares if they are crap, they are very cheap, and look OK to do the job.
  5. Stinja
    Stinja
    Aug 13, 2003
    12,846
    163
    +4,204
    Ha ha you're right :oops: I think i was looking at some others that were like £25, but these seem better designed, and my brain hadnt acknowledged the price.
    I'll order some up and write up my thoughts if people are interested; while you might not take them on the road, probably real useful when at home for those longer sessions.
  6. Stinja
    Stinja
    Aug 13, 2003
    12,846
    163
    +4,204
    Ok they arrived.
    Fairly solid, the rubber bits arent vert rubbery, but still grippy enough. It attaches to the PSP quite firmly and most importantly does help with handcramp, as theres just more to hold onto. Obviously it adds way more bulk, but good for sitting down sessions at home.
    I cant quite put my finger on it, but its not as comfy as a dual-shock, but certainly better than trying to delicately hold the PSP by itself. So yeah a decent buy for a fiver.
  7. h0l1yw0od
    h0l1yw0od
    Nov 16, 2000
    477
    +13
    Yeah i got the Black ones in the end from here http://www.gameseek.co.uk/pd/PSPvg0y60z6bn7zf9h2/Gamester-Black-PSP-Comfort-Grips. They do the job nicely and come with a overall clear case that snuggly wraps the PSP. I would have liked a little foam inside at strategic points just so theres no risk of the plastic rubbing or scuffing the PSP itself, but i've seen no evidence of this.
    Worth the buy for all round protection and comfort use. :thumbsup:
  8. semiskimmed
    semiskimmed
    Jun 30, 2005
    5,125
    Nottingham
    +260
    that looks like a great add on for the larger handed players out there
    i didnt even know these existed cheers for the info
