PSP connection error (80410B05) PLEASE HELP!
Discussion in 'Playstation Forums' started by matt_du_man, Sep 6, 2005.
  1. matt_du_man
    matt_du_man
    May 15, 2005
    26
    3
    Hi, i got my PSP 2 days ago, and immediatley updated to version 2.00, but when i go into game sharing, i get the message
    "a connection error has occurred. (80410B05)"
    (and yes my WLAN switch is ON)
    now i dont know if the update has anything to do with this because i didnt get the chance to try game sharing beforebefore i updated.
    please help me, ive looked all over the wb, but all i can find are connection errors to do with network settings
    P.S - i am taking it to the sony shop tommorrow, but if anyone can help me before hand, i would be greatly appreciative
    thanks in advance
  2. IanW
    IanW
    Feb 28, 2001
    1,618
    Wiltshire
    +152
    Check out the Firmware 2.0 thread in PSP area. I assume you are trying to connect via WPA, we have now proven that this normaly does not work; there is only one or two routers that will work.
    Ian.
  3. matt_du_man
    matt_du_man
    May 15, 2005
    26
    3
    i think you misunderstand me, i am not trying to connect to a router wirelessly, i am simply trying to connect to another psp using wifi, no network settings are needed.
  4. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,225
    +6,432
    and you followed manual instuctions to letter? hmmmmm
  5. bellso
    bellso
    Apr 21, 2004
    1,476
    Leeds, U.K.
    +319
    Is the other PSP a UK version?? If not it won't work.
    Can only connect same Country psp's together [or so i am led to believe?]
  6. cj101
    cj101
    Apr 1, 2005
    70
    lowestoft
    I have in my hands a US PSP which is connected wirelessly to a UK PSP my son is using. We are playing Ridge Racer. PSPs are not the issue, the games are. Both games must be from the same region, ie UK game playing a UK game.
  7. matt_du_man
    matt_du_man
    May 15, 2005
    26
    3
    dont worry, i have taken it to the sony shop and they couldnt figure it out, so they are going to do a straight swap for a new one, will be getting it tomorrow! :thumbsup:
  8. Coulton
    Coulton
    im having the same problem....please help!!!!:lease:
  9. leamspaceman
    leamspaceman
    Jun 22, 2004
    6,981
    +3,038
    Let us all know the outcome mate.
  10. Coulton
    Coulton
    any luck? i need to know whats wrong with mine...
