Psp 8
Discussion in 'Photography Forums' started by Bexlee, Sep 14, 2004.
  1. Bexlee
    Bexlee
    Apr 25, 2003
    95
    South Yorkshire
    When I have done a bit of basic editing, such as red eye removal or a little cloning, originally large photo files (around 2000KB) will be saved as much smaller files- as low as 400KB.
    Why does this happen & how can I prevent it?
  2. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    Are you saving it at less then 100% quality.
  3. RobertP
    RobertP
    Nov 21, 2002
    529
    19
    Woodford Essex
    As Keanyboy says really.
    With any editing program you want to keep your original as it is and 'save as' (with a new file name) once you have edited. That way if you screw up you have not lost anything.
    In psp8 when you 'save as' you have a drop down box where you choose the file type and lower down an options button - that is where you set the quality (file compression) and therfore the size of the saved image file.
  4. Bexlee
    Bexlee
    Apr 25, 2003
    95
    South Yorkshire
    Thanks guys- I see it now- in 'options' after 'save as'. Presumably the 'lossless' option would keep the image the same quality automatically.
    I always keep original images so it will just take a bit of time to retouch a few pictures.
