PSOne to VGA?
davidlqs
Hi all,
I've just bougt a PSOne from eBay which has an output SCART cable with a 3-phono breakout. I'd like to connect the output to a pc monitor via a VGA dsub (or DVI) input. Is there a cable which I can connect either directly to the PSOne output, or to the 3-phono breakout?
tia
David
Chox1988
playstation2 leads are compatible with the psone.
if you go here you can see there are component and composite leads available dependant on what options your tv has, but vga as above means a conversion box and £££. Decide on a lead type and find somewhere you are happy to buy from and it should work. :)
http://www.happycomputing.com.au/category35_1.htm
Many tv's though look best with such a low quality interlaced image running through scart, and there will be little or no difference between component and composite because few games are progressive scan anyway.
