PSM192 and TH-50PHW6 advice needed
Discussion in 'TAG McLaren Audio Owners' Forum' started by mule91, Feb 20, 2005.
  1. mule91
    mule91
    Sep 20, 2003
    22
    UK
    Hi, I have a DVD32FLR and a Panasonic TH-50PHW6. I’m considering having a PSM192 but I am worried about the DVI issues with the Panny. Can anyone tell me if the interlaced single is carried through the component BNC’s as well as the DVI? I’m already using a component card in the Panasonic.
    Many thanks.
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    I think you mean "de-interlaced"? If so the "de-interlaced" signal is present on the BNC output of the DVD as well as the DVI connector, the RCA output remains "interlaced". Personally I'd connect up using the BNC's to the Panny, it was well documented that there was a whole world of grief using the Panny's DVI input (not just with the PSM!).
  3. mule91
    mule91
    Sep 20, 2003
    22
    UK
    Thanks Graham.
    Sorry, I did mean de-interlaced.
    Basically what I really want to know is:-
    what are the disadvantages, if any, of using the BNC component compared to DVI?
    Will I loose any functionality?
    Thanks again.
  4. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Functionality, Nope.....
    Disadvantages, well, three off component cables might be dearer...... :devil:
    The rest depends on how well the DVI or component inputs on the display are implimented.... e.g. one mght be delibrately made inferior to the other..... ;)
  5. lovegroova
    lovegroova
    Jul 15, 2002
    2,729
    103
    Herts
    +387
    I use a PSM with a 42" Panny 6-series and have it connected using the BNC (to RCA) component. I did buy a DVI board from these forums, but the Panny won't accept a PAL 50Hz signal via DVI and is therefore no good for watching british TV or R2 DVDs.
    Also, with the DVI board inserted in socket 1, the component board in socket 2 stopped working.
    Finally, use the money you have saved by not buying a DVI board, and get someone to calibrate the screen properly for you. It'll make a much more significant difference to the picture quality than the type of connection you use.
    My advice is to use the component connections, they really are very good indeed.
  6. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Component it is then......... Digital world eh, you cares when you get a better picture eh.......
  7. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    Maybe it's just me but I have feeling I have better picture over component, whatever the reason!
  8. mule91
    mule91
    Sep 20, 2003
    22
    UK
    Cheers all.
    I've already got a good BNC componant lead (Belden 7710A) so I'll proceed with that.
    Thanks again.
  9. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    With a Panny 6 series?? Not watching many R2 DVD's then?
  10. mule91
    mule91
    Sep 20, 2003
    22
    UK
    Suely you can't take sky or any other PAL 50hz signal throughthe DVI either?
  11. lovegroova
    lovegroova
    Jul 15, 2002
    2,729
    103
    Herts
    +387
    Graham, what do you mean by this? Me no comprendo!
    Is it something to do with panel resolution? Or do you think that Plump meant that he thought DVI was better than component? :confused:
  12. OnTheFly
    OnTheFly
    Jul 2, 2002
    3,011
    83
    Everywhere
    +119
    I am under the impression that the BNC's offer PS, whereas the DVI offers PS and the scaler. The DVI would be wasted considering the Panasonic plasma issues.
    Of course, members more 'in the know' may correct my beliefs! :suicide:
  13. mule91
    mule91
    Sep 20, 2003
    22
    UK
    We seem to have a conflict of opinions here. Does the PSM192 carry scaling through via BNC componant?
  14. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Wooooha.........
    The PSM doesn't do any scaling at all ever...... It just does de-interlacing and the SAME signal (720x576p or 720x480p) is available via either the DVI connector or the BNC's, the standard interlaced output (720x576i or 720x480i) is still available via the RCA's and the s-video and composite outputs.
    The Panny 6 series DVI input didn't accept a 50Hz PAL signal, so if you play a R2 DVD in the DVD32R/PSM it don't work properly. The DVD32R does not convert between NTSC and PAL sources. It does allow either RGB or Component video output from the PSM ports though.
    DVI is frankly not better than the BNC output on the DVD32R/PSM... It is all down to the display and what it makes the best job of.
    If you need scaling then its either the VSM module for the AV192R or similar off board scalers from Lumagen etc. Of course using the displays internal scaling is the other option which may or may not be bypassed if you use the display's DVI input.
  15. mule91
    mule91
    Sep 20, 2003
    22
    UK
    Thanks for putting me straight on this Graham. :thumbsup:
  16. OnTheFly
    OnTheFly
    Jul 2, 2002
    3,011
    83
    Everywhere
    +119
    Thanks GrahamMG
  17. PhilCTTE
    PhilCTTE
    Aug 28, 2001
    1,690
    W.Mids
    +133
    Maybe one of the old Tag helpdesk personnel could help hear Roversd1 ? The issue was with the PAL signal and the number of lines 572...574 If I recall the Panasonic DVI board couldn't interpret correctly. Panasonic said tough luck :eek: ! So Tag as wonderful as they were updated the software to configure the number of lines output from the DVI. By this time tho I'd swapped the Panasonic for a Pioneer. So i'm not sure if this fix ever was released
