PSM s-video input and RGB->s-vid converter
Discussion in 'TAG McLaren Audio Owners' Forum' started by cskates, Feb 1, 2005.
  1. cskates
    cskates
    Jul 5, 2001
    151
    Belfast, UK
    I have a DVD32FLR with PSM fitted and for the first time since I got the player I was able to use the progressive output into a projector at the weekend. The PSM produced a wonderful picture from the FLR, but when I connected my Gamecube to it (through a JS RGB->s-vid converter) I got coloured lines across the screen. eg. blue skies would have flickering lines of red, yellow areas would have lines of green and red. Fortunately when I tried looping the FLR's s-vid input into the PSM, or using the s-vid from another DVD player the picture was fine which suggests the RGB->s-vid converter is at fault and not the PSM itself. Connecting the converter directly to the projector or a TV is fine.
    Has anyone else used a RGB->s-vid converter in conjunction with the PSM?
    Does anyone have a suggestion as to what could be the cause of the noise?
  2. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Is your games console trying to output a PAL 60 signal? I had a similar problem with my x-box feeding my Lumagen (which uses the SIL504 as in the PSM) I just had to go into the set up menu on the x-box and switch PAL 60 off. After this it was fine :thumbsup:
  3. PhilB1234
    PhilB1234
    Does the GameCube have an accessory lead that provides a direct and unconverted S-video feed? I know they are common for the PS and X-Box, and this may be the best bet (particularly if you can get a refund on the RGB > S convertor)......
  4. lovegroova
    lovegroova
    Jul 15, 2002
    2,729
    103
    Herts
    +387
    Try connecting the Gamecube to the 'Sat' s-video input on the AV32R as this has something called a DC offset on it. I was experiencing problems with lines across the screen and this sorted it out.
  5. cskates
    cskates
    Jul 5, 2001
    151
    Belfast, UK
    Unfortunately the European Gamecube cannot output s-video natively hence the converter. IIRC the converter will output NTSC or PAL depending on whether the input is 60 or 50Hz, though next time I will try forcing the Gamecube to 50Hz output to see if that makes a difference. I should've also tried connecting a different RGB source to the converter. I'll try all these suggestions next time I get access to the projector :thumbsup:
  6. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,350
    Livingston, Scotland
    +227
    CS
    Have you tried a Joytech Games reciever in the chain? Forget what it is called exactly but it has 4 or 5 inputs, each with SCART, S-Vid and Composite and can output in any of those.
    A friend has one (admittedly not into a TAG) for use with PS2, X-Box and Game Cube and it works well. It's about £60 and comes with an RC
  7. lovegroova
    lovegroova
    Jul 15, 2002
    2,729
    103
    Herts
    +387
    In that case, do try connecting the convertor to the AV32's Sat input, and then the AV32 to the DVD32. I use a JS tech convertor from my NTL cable and had to connect it to the Sat input. Give it a try - it could be a cheap fix! :thumbsup:
