PSM Module DVI >> Panasonic Plasma
Discussion in 'TAG McLaren Audio Owners' Forum' started by PhilCTTE, Nov 13, 2003.
  1. PhilCTTE
    PhilCTTE
    Aug 28, 2001
    1,650
    W.Mids
    +130
    Anyone here tried the PSM module in the DVD32R to a panasonic 42" 6th series plasma via DVI ?. Any success ?
    I'm trying to configure the plasma to RGB digital input and the PSM module to RGB output.
    I'm having a spot of bother. Just spoken to the plasma retailer and mentioned that I couldn't change via the menu the input selection to RGB. I can only access the input labels. Which I might have changed by mistake, so I'm trying a factory reset tonight. The problem is the menu option is greyed out for the input option change from component to RGB, therefore I'm assuming that I need to be on the right input selection of RGB digital before I can change it and if the labels are messed up then this could be my problem. Any thoughts before tonight would be appreciated especially if anyone is successfully using this combination.
    TIA.
  2. PhilCTTE
    PhilCTTE
    Aug 28, 2001
    1,650
    W.Mids
    +130
    I've just been informed that Panasonic know of this problem and are looking into it !!! Aarrgh!! Many thanks to Liam at AV sales and Tag help desk ...
  3. BertG
    BertG
    The TY-42TM6D DVI input card is described as
    "Wide Plasma Display RGB (digital) Terminal Board"
    It only does RGB.
    Presumably it doesn't work, any idea what the problem is?
  4. PhilCTTE
    PhilCTTE
    Aug 28, 2001
    1,650
    W.Mids
    +130
    The panasonic DVI board doesnt seem to understand the PAL signal currently. Panasonic are working on a fix. Follow the thread on the Tag website for updates.
  5. Plump
    Plump
    Feb 22, 2002
    636
    19
    under the bridge
    Panasonic is working on that but do not expect them to upgrade current models
    Next genereation maybe
  6. PhilCTTE
    PhilCTTE
    Aug 28, 2001
    1,650
    W.Mids
    +130
    If it is isolated to the DVI input board then they should simply replace this (as it is removable) and not the whole plasma. Also I shall do some major stomping up and down if they dont fix it after all its a sold as a UK PAL model !!!
  7. PosiXX
    PosiXX
    @ PhilAllaway,
    Do you have tested the new DVD32R sofware with your panny? Since it should correct the difference in lines the panny accepts, according to the TM helpdesk.
    I really want to know before i decide to buy the DVI board..
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Out of interest if Tag, Iscan and others were outputting 572 plus 4 blanking lines, and the Panny working 'to spec', who was to blame? ;)
