Pse Help To Get Kameleon 6 To Recognise Ntl Cable Tv Box
Discussion in 'Cable TV & Virgin Media TV' started by bondy, Oct 18, 2003.
  1. bondy
    bondy
    Bought the Kameleon 6 today but I cannot get it to programme for my (bog standard) NTL Cale TV set top box (a PACE DITV-2000). Can anyone help please - otherwise it is going back to Dixons tomorrow!
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,261
    Rainham Essex
    +2,404
    I know the Pace 1000 & I think the 2000 also use a different IR system for their remotes, therefore many universal remotes can not control these boxes.
    Mark.
  3. bondy
    bondy
    Thanks Mark but I have managed to get it working and must say that the Chameleon is very impressive.
  4. Kingy
    Kingy
    Jul 17, 2003
    76
    +4
    I couldn't get mine to work with standard codes from manual but it was easy to do with learning facility :D
  5. The Robman
    The Robman
    If there are any codes missing from the URC-8060, you can add them using the modem, either from the OFA web site or over the phone.
