PSB Imagine XA Dolby Atmos Speaker Review & Comments
Discussion in 'Home Cinema Speakers' started by Steve Withers, Dec 28, 2016.
    1. Steve Withers
      Steve Withers
      Reviewer
      Oct 18, 2009
      9,590
      +9,042
      Nothing at all and the wall mounts mean you can place them just above the 3010s if you like.
    2. Rodio
      Rodio
      Oct 22, 2015
      26
      11
      2
      7
      Belfast
      +3
      What's the recommended sitting distance from the speakers? I sit 10ft from them, they are almost 3 feet off the ground (base of atmos) and 6ft from the ceiling. I disconnected my rear surrounds to hook these up on Yam A1060, set the amp config to 5.1.2 and ran YPAO. It's now telling me all my speakers are reverse phase!? Re-ran several times after moving mic, speakers etc but every time phase warning ⚠️, not just one speaker but all of them!? I have triple checked the cables and inputs, everything is correct. I'm also underwhelmed with the effect. I noticed in the manual it says in bold letters that they MUST be in phase to work properly. Truly baffled
    3. One more thing
      One more thing
      Feb 15, 2012
      897
      Bristol
      +87
      Nice review, thanks. Am currently running 3.1 as my sofa is up against a wall and surrounds seem like a bad choice if I can't get them in the right place, plus I have a door when one should go.
      So, might be a crazy idea but what if I used these speakers or similar on my front book shelf speakers wired into the surround channels so effectively it would be 3.1.2 but only being fed surround info and not atoms as my AVR is MRX310 and only 5.1.
      Plus my ceiling is 2.7m high so a bit higher than average, I guess that can only be a good thing so the sound appears to go further back above you? I sit about 3m from mains. Ceiling is flat though.
      Any advice much appreciated!
    4. gibbsy
      gibbsy
      May 17, 2007
      10,953
      3
      Cwm Cynon, De Cymru
      +5,764
      You would need an Atmos enabled receiver in the first instance. Your ceiling height would not be a problem. However, I don't think a 3.1.2 would work, it gives the sound nowhere to travel to. Correctly set up my KEF R50s gives a smooth transition of sound between the fronts and surrounds by filling in the height gap. It's effective and very pleasant, the bubble that everyone talks about.
      Even though you sit against a rear wall surrounds can still be effective at the side if this is possible.
    5. One more thing
      One more thing
      Feb 15, 2012
      897
      Bristol
      +87
      Thanks. If I went for surrounds the only viable place would be roughly 2m up above door frame angled down at MLP. Doing you think this would be ok? Be in corner too?!
    6. gibbsy
      gibbsy
      May 17, 2007
      10,953
      3
      Cwm Cynon, De Cymru
      +5,764
      Most will have to make compromises with the set up unless you're in a dedicated room. One of my surrounds is in a corner and I have no problems. It is also slightly higher than the guide lines give. I would personally rather have a less than perfect placement of surrounds rather than none at all.
      Speaker choice would need to be one with a wide dispersion.
    7. One more thing
      One more thing
      Feb 15, 2012
      897
      Bristol
      +87
      Thank you. Was looking at the SVS prime elevation as it has a nice angle firing down. Prime Elevation doesnt say much about dispersion though but assuming it would be ok?
    8. smokingreen
      smokingreen
      Apr 23, 2004
      681
      Derby
      +17
      I have bipole surrounds on rear wall and they work well, approx 0.8m above MLP.
      I've just got some MA silver FX to go on the back wall this weekend replacing my trusty old Mision M7DS.
      I was thinking of trying upfirers, but decided on surround upgrades for now.
    9. One more thing
      One more thing
      Feb 15, 2012
      897
      Bristol
      +87
      Are you sat up against that wall though on sofa like me? I feel like I'd almost be under the drivers, but maybe that's a good thing with surrrounds?
    10. smokingreen
      smokingreen
      Apr 23, 2004
      681
      Derby
      +17
      Yes, the sofa is against the back wall. The speakers are about 0.8m above and approx 1m either side of the MLP. The bipole speaker keeps the sound diffuse and gives a good surround affect.
      However from what I have read, high surrounds do not work well with atmos as there is too much going on above.
    11. gibbsy
      gibbsy
      May 17, 2007
      10,953
      3
      Cwm Cynon, De Cymru
      +5,764
      They look interesting. The site I found says you can have a 45 day home trial. Your position problems could very well be addressed to some extent with these particular speakers and should prove enjoyable even in a 5.1 set up.
    12. One more thing
      One more thing
      Feb 15, 2012
      897
      Bristol
      +87
      Thanks again, BTW which site had the 45 day trial?
    13. gibbsy
      gibbsy
      May 17, 2007
      10,953
      3
      Cwm Cynon, De Cymru
      +5,764
      Ah, it was the US home site, but there is interesting information on there.
      Prime Elevation
      In your situation I would be very tempted with these speakers, there are several good reviews on Google.
    14. fayeanddavid
      fayeanddavid
      Sep 23, 2009
      5,505
      Bearsted Kent
      +1,918
      So reading the manufacturers blurb on the PSB Atmos speaker they allude to the Dolby crossover design which cuts at 7kHz and boosts at 12kHz for Atmos
      Anyone out there who can tell me why and what for, very interested??
    15. fayeanddavid
      fayeanddavid
      Sep 23, 2009
      5,505
      Bearsted Kent
      +1,918
      Anyone please....
    16. kobebeef
      kobebeef
      Jun 4, 2016
      174
      United Kingdom
      +89
      This is a useful watch:
      KEF R50 Atmos Enabled Speaker with Mark Dodd...
      The chap claims it's boosted around 5 and dipped at 10. It's also a bit weird why PSB have that intricate cover when everyone else doesn't bother and have gone with a conventional, flat grille.
    17. fayeanddavid
      fayeanddavid
      Sep 23, 2009
      5,505
      Bearsted Kent
      +1,918
      I'll have a look see, thanks
    18. gibbsy
      gibbsy
      May 17, 2007
      10,953
      3
      Cwm Cynon, De Cymru
      +5,764
      Very interesting clip. I really do agree with him on music especially from live concert discs that can be upmixed, DTS-HD MA + Neural:X is very good indeed. Besides that the KEF R50 must be the best looking module available.
    19. springtide
      springtide
      Oct 7, 2005
      5,157
      +1,154
      Has anyone a comparison of these vs the Onkyo 410s (or even Kef)?
      I currently have the 410s as a stop gap; just upgraded the fronts to Silver 8s and the Onkyo's look terrible, so wondering what to replace them with.
      There are also the SVS Prime Elevation Speakers as another option (£200), but these seem like they are not suitable for upfiring, but would need to be mounted high on the front wall.
      Anyone?
    20. tiberian9
      tiberian9
      Dec 20, 2005
      28
      +32
      I have just replaced my Onkyo 410s with PSB Imagine XAs and have them partnered with MA silver 6s. I have only had a chance to watch a couple of movies with them, but first impressions are encouraging.
      When running test tones during setup the XAs sound a much closer match to the Monitor Audio silver series speakers that make up the rest of my system than the Onkyos which always sounded weedy in comparison.
      During use there is much less direct sound coming from XAs than there was with the 410s. The sound definitely seems to come more from above and be more what I was expecting from Atmos.
      The two films I watched were Unbroken and Gravtity and I was impressed by the sound of both. I am well happy with the upgrade.
      Hope that helps a little.
    21. turk182
      turk182
      Jun 7, 2005
      3
      +4
      Just finish installing PSB Imagine XAs front and rear, from the onkyo (front only), just watch Deepwater Horizon the dolby atmos was stunning, totally immersed into the movie, atmos at its best, that bird at the start scared the be`jesus out of me :)
    22. UPTHEOWLS
      UPTHEOWLS
      Jun 27, 2011
      568
      Seaton, Devon
      +287
      I have an artex Ceiling :eek: Would the PSB XAs work ?
    23. gibbsy
      gibbsy
      May 17, 2007
      10,953
      3
      Cwm Cynon, De Cymru
      +5,764
      My ceiling has a stiple artex effect and the KEF R50s work well.:smashin:
    24. UPTHEOWLS
      UPTHEOWLS
      Jun 27, 2011
      568
      Seaton, Devon
      +287
      Thanks, sounds like same as mine swiles in circles and is stipled !!
    25. charles
      charles
      Jul 6, 2001
      1,389
      63
      norwich
      +196
      Regarding the rear Atmos speakers is it a good idea to have them either on the rear wall or mounted on stands. I was thinking of the stand option,
      preferably an adjustable stand so that one could make sure that they would be in the optimum position. It is not possible to sit them on top of my rear speakers.
    26. gibbsy
      gibbsy
      May 17, 2007
      10,953
      3
      Cwm Cynon, De Cymru
      +5,764
      Perfect solution.
    27. Bl4ckGryph0n
      Bl4ckGryph0n
      Sep 11, 2003
      38,411
      10
      13
      ::1/128
      +12,297
      I decided to go with these for my step into Atmos. They arrived today, but duh I forget they require speaker cabling.....Silly me....
      • Like Like x 2
      • Funny Funny x 1
      • List
    28. MrTea34
      MrTea34
      Jan 12, 2017
      101
      GB
      +22
      These are the Atmos speakers I have bought recently but haven't had chance to properly test them out yet but they look the part.
      Have only watched one Atmos film, Pan and it sounded amazing and I'm probably sat abit to far back than required ( only slightly) but all the speakers working together created a bubble of sound.
      Not sure if you've seen Pan but the part where the planes attack and fly.overhead sounded great and had me fully immersed.
      The speakers come with discrete wall mounts
    29. mikemag
      mikemag
      Jun 5, 2007
      3,307
      167
      +8,030
      Be interesting to hear your thoughts whenever you do get them up and running.
    30. gibbsy
      gibbsy
      May 17, 2007
      10,953
      3
      Cwm Cynon, De Cymru
      +5,764
      Don't forget to EQ them either. I would lift the levels a little over what Audyssey suggests and certainly take the crossover to 120hz at the very least. For sheer immersion and listening enjoyment for me it's been money well spent.
      • Like Like x 2
      • Agree Agree x 1
      • Useful Useful x 1
      • List
