I just know someone will end up using it as a coffee table. I could get a custom cut bit of safety glass but worry that will rattle. Any better suggestions?
I'm sure I've seen people use glass OK. Probably with some sort of compliant rubber feet to separate it from the sub I'd have thought? Any sort of fabric covering won't rattle of course but it may not be the look you want.
