PS42V4S or TH37PE50
Discussion in 'Plasma TVs Forum' started by ZeroT, Apr 26, 2005.
  1. ZeroT
    ZeroT
    John Lewis have a good deal on both of these sets at the moment.
    Can I possibly get comments on both sets.
    Not to fussed about the free recorder with the panny but if its a better screen then I can use the recorder elsewhere. The Samsung would ppear better just because it was a much higher price to being with (get what you pay for?)
    From my initial findings it looks like the Samsung is better on paper with HDCP and a DVI connection and the panny not having either (according to their site). But as well all know its not down to the paper specs but what they perform like.
    http://www.johnlewis.com/Shopping/P...=Televisions&PRT=Plasma&Type=SKU&Id=230200692
    http://www.panasonic.co.uk/plasma-tv/th37pe50ped/index.htm
    Comments on both please :)
  2. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    errm the samsung does not have hdcp on the dvi port. I checked this with samsung uk myself(when i had mine). And PQ is crap! check some of my other posts.....
  3. ZeroT
    ZeroT
    Thanks for the HDCP update, I only found that info on the Comet site so wasnt sure anyway!
    So on that note you are pushing the panny out of the two I take it.
    I am starting to like the panny after some more research, any bad comments?
  4. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    If i had to choose again out of those two the panny would win.
  5. WhiteNoiseMaker
    WhiteNoiseMaker
    Mar 4, 2005
    42
    +4
    I've ordered a TH37PE50 with free DVD recorder from John Lewis today, as everywhere else had no stock. The 5 year guarantee on the screen and the 2 year guarantee on the DVD recorder are excellent.
    They are going to deliver it next week on Friday!
  6. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    after reading your first post again, it may be better for you to wait till next month and get a demo of the panny pv500 (looks like you want hdtv/hdcp compatible screen).
  7. Llanowar
    Llanowar
    Jan 30, 2005
    387
    16
    Amsterdam
    I got the 37 inch panasonic, great screen, especially with sd content, very pleased so far, it does have a humm though, going to ask panasonic about this...
  8. ZeroT
    ZeroT
    Do we have a price projection on a 37" PV500 if there is going to be one?
    I have seen the 42" PV500 comming in at 2k ex vat but would be more interested in the 37".
  9. Peabo
    Peabo
    How much are you willing to spend? Does it have to be bought from John Lewis?
  10. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    418
    +10
    If you have any regard for PQ whatsoever, avoid the samsung. I swapped mine for a PWD6 and cannot begin to explain the improvement.
  11. ZeroT
    ZeroT
    Deff doesnt have to be brought from John Lewis at all, am willing to shop anywhere.
    I havent set myself a budget yet as I would rather see what sort of prices are available on the 37" and 42" and then go from there.
  12. dognuts
    dognuts
    Feb 13, 2005
    444
    +26
    Try www.totaldigital.biz
    Ive just ordered a TH42PE50 for £1560 inc delivery and free pedestal stand.
    I think the 37" is about £1300 with free pedestal or wall bracket.
    Ive never used them before but they seemed fine on the phone.Fingers crossed.
  13. ZeroT
    ZeroT
    I'm going to hold out for the moment and see what sort of price I can get a 37" pv500 for I think.
  14. Peabo
    Peabo
    Good choice! :)
