Question ps4 pro green bars / no pic on 4k
Discussion in 'Playstation Forums' started by ollski, Aug 3, 2018.
  1. ollski
    ollski
    Dec 27, 2009
    58
    pershore
    Hi anyone else got this?, plugged straight into a lg e6 oled with HD RGB and deep colour on. Sometimes it will work perfectly and I can use it until I turn it off, The next time I may just get small horzontal green lines at each side of the picture which make it judder but I can play games ok. A few times the screen has gone entirely black or like the old untuned analogue channel type of interference screen and then the tv reports no signal which means I have to unplug the ps4 and reset.
    I bought a new cheapish 2 metre HDMI cable which said it was 4k compatible but it was the same or worse. Im at a bit of a loss if im looking at a tv, ps4 or cable problem
  2. tommitch
    tommitch
    Jun 2, 2016
    777
    96
    London
    +858
    Do you have another TV anywhere you can test to see if you get the same issue?
