PS4 PRO Enhanced 4K issue on Denon AV receiver
Slider09
EDIT: All sorted now.
Hi all
Bought a PS4 pro last night and hooked it up to my Denon AVR-2400 receiver. Currently my receiver and tv are set to ‘enhanced 4K’ mode. Immediately it didn’t work, the sound would be intermittent and there was no video.
Plugged the PS4 direct to the tv and everything was fine. Connected it back to the amp and again it’s not working. However, setting the 4K mode on the amp to standard instead of enhanced works. I’ve swapped cables around, so using the supplied PS4 hdmi cable from both PS4 > amp and amp > tv and it makes no difference.
So, looks like I need to replace my current 4K hdmi cable (which works fine with Sky Q and Nvidia Shield).
Any recommendation of a hdmi cable which is fast enough to cope and compatible with the PS4 Pro?
