Question PS4 Pro & Elgato HD60
Discussion in 'Playstation - PS4 & Vita' started by mufc4eva, Jan 27, 2017.
  1. mufc4eva
    mufc4eva
    Oct 25, 2007
    2,466
    63
    +215
    Why can I not get my Elgato HD60 to work with the Pro? There is sound on the TV and in the Elgato software but the display shows a black screen on both. I have unticked the HDCP box in settings, HDR is turned off and resolution is set to 1080p.
    It's been bugging me for the last two hours, everything I have tried is a no go. I tried it with the Xbox One S and that works fine, so I am rather puzzled right now!
  2. mufc4eva
    mufc4eva
    Oct 25, 2007
    2,466
    63
    +215
    It's actually not working on the One S either.
    Have plugged an old 360 in and it works perfectly fine (but no use to me)
    I've tried disabling HTCP, change the resolution to 1080p (even tried 720p), have tried pretty much everything but just a black screen with sound.
    Any ideas anyone?
