PS4 Pro buying advice
indus
Thinking of buying a PS4 Pro and I know nothing about games consoles.
I will probably buy new but just in case something comes up second hand I might go for it.
Is there anything I should be looking out for ie are there different generations of the PS4Pro? Is there a particular bundle that represents good value etc?
Thank you.
indus
You should get the CUH-7216B version of the Pro, the other have a noisy fan and a coil whine noise.
Thanks.
I've ordered one from Amazon but they don't give details of model numbers. If it's not the model with the quieter fan I'll return it.
Game make it clear by calling it the 'gamma chassis' but I wanted the easier returns/warranty of buying from Amazon.
LG CX 4K OLED TV Review: The best TV of 2020?
