PS3, yamaha amp, HDMI
Discussion in 'AV Receivers & Amplifiers' started by calot, Jun 16, 2008.
Tags:
  1. calot
    calot
    Jun 16, 2008
    11
    How do I connect my ps3 to my amp and tv, so that I can get 6.1 in my yamaha amp? The yamaha amp has 2 HDMI slots and my tv also has...
  2. calot
    calot
    Jun 16, 2008
    11
  3. calot
    calot
    Jun 16, 2008
    11
    Do I just connect the ps3 with HDMI to the tv, and the tv to straight to the amp?
  4. Whisler
    Whisler
    Mar 5, 2007
    393
    28
    Croydon, Surrey
    +25
    couple ways to do it
    i would just run your ps3 into the amp via hdmi then hdmi out from your amp too your tv, youll get the sound and the picture through the amp, or you can do optical in to the amp and then hdmi in to the tv if you dont want the picture going thru the amp. but id imagine the amp wont touch the picture neways not sure tho someone will confirm. but id do hdmi, all the way one less cable too hehe.
    if ofc your amp doesnt have hdmi out then optical into the amp and hdmi to tv.
    Mark
  5. calot
    calot
    Jun 16, 2008
    11
    I already bought two HDMI cables. But its ok, if I dont need one Ill just go and return it since its not open yet. If I use digital audio out from the ps3 to the amp will I still get 6.1? I dont know if the amp has HDMI out... it arrives in a couple of days...
    and thanks for the quick response
  6. calot
    calot
    Jun 16, 2008
    11
    Im reading up on the info and it says that upconverts image from analog sources.. Will that work the same as HDMI? I dont think so...
  7. calot
    calot
    Jun 16, 2008
    11
    kewl
  8. alchemistkevin
    alchemistkevin
    Sep 6, 2007
    3,632
    Surrey
    +133
    PS3 --> HDMI to amp
    any other devices in the future --> HDMI to amp.
    amp --> HDMI to Telly.
    So all the sound goes via the amp via a single cable and one single cable to the telly, unless of course if you have a sky box you will probably need to scart to telly and audio to amp.
