PS3+xbox360 with panasonic 37PX70 plasma or 32LXD70 LCD?
Discussion in 'Panasonic TVs Forum' started by lében, Apr 22, 2007.
  1. lében
    lében
    Apr 22, 2007
    20
    Hi there!
    I am going to buy a new HD ready tv for xbox360 and ps3.But there are lots of model and I am confused.Finaly I have found some models
    TH-37PX70 plasma tv
    or
    TX-32LXD70 lcd tv
    their sizes and prices are okey for me but I am wondering about their picture quality and compatibility with nextgen consoles.plasma's black and color quality is amazing but resolution is not 1366 x 768:mad: is this a problem with consoles?
    waiting your posts!
  2. AndrewTheMuppet
    AndrewTheMuppet
    Dec 3, 2004
    195
    +3
    Plasma Will be better. As you say, better blacks but also generaly better with motion. It's bigger too of course !!
    Don't worry about resolution. At least not at this screen size.
    You only need to worry about that when you get to 50" and these are 1366x768 anyway.
    Might want to find out about the "purple snakes" on the Panasonic though .
    Not sure about the 70 series but the 60 series has had reports of problems.
    Andrew
  3. lében
    lében
    Apr 22, 2007
    20
    thanks.How about somsung's new 9x plasma series?
    as I look their specifications it looks better .Can you compare them with 37PX70?
  4. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    The spec doesn't really tell you much of worth I'm afraid. You'll have to go & look & see what you think. The PX70 is about the best buy at the price imho.
  5. lében
    lében
    Apr 22, 2007
    20
    has anyone tried ps3 with 37PX70? can this support 1080p via HDMI?
  6. Zippster
    Zippster
    Dec 31, 2002
    203
    +5
    the 42" does just fine, so should be no probs with teh 37"
  7. lében
    lében
    Apr 22, 2007
    20
    does this mean: as the screen size decreases(while resolution is same) the quality increases?
  8. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    The resolution isn't the same, although it's close.
    But to answer the question, yes, as long as you don't mind a smaller picture.
  9. lében
    lében
    Apr 22, 2007
    20
    Are there any differences btw PV70 and PX70 except DVB tuner?
