PS3/Xbox360 connection issues
Discussion in 'Playstation Forums' started by reddevil63, May 2, 2007.
  1. reddevil63
    reddevil63
    Apr 12, 2005
    5,538
    Disney Florida's Twinned Town
    +851
    Have only recently bought a PS3 which sits along with my 360.
    Up to now the 360 had been the only thing connected to my router and have had no connection issues whatsoever.
    Since getting the PS3 all I do is take the ethernet plug out of the back of the 360 and plug it in to the back of the PS3 and vice versa, this is done while both consoles are powered off.
    Now have this problem!
    Can connect to the PS network ok, can get into the PS Store, can even use the web browser but have tried going online with Motorstorm, RFOM and F1 and always get message 'unable to connect to server, please check your network settings'!
    Confused now as the internet connection status within XMB shows everything ok and have a NAT type 2 which is supposed to be good.
    Am using the wired method of connection to my Linksys BEFSR41 ver.2 router.
    Any ideas guys?
  2. Tony Hoyle
    Tony Hoyle
    Aug 4, 2005
    3,347
    103
    Stockport
    +231
    Could have been some issue the time you were connecting? If you can browse the web then it should work.
  3. reddevil63
    reddevil63
    Apr 12, 2005
    5,538
    +851
    Well I tried last night and no joy and just fired it up again and still can't do online games.
  4. druidvideo
    druidvideo
    Apr 22, 2005
    95
    11
    London
    +7
    It definitely sounds like a NAT issue. Had the same thing with the 360. Try setting up DMZ if your router has that feature and set your PS3 to that address or range.
  5. reddevil63
    reddevil63
    Apr 12, 2005
    5,538
    +851
    But I have NAT 2 which according to Playstation website is good.
  6. Tony Hoyle
    Tony Hoyle
    Aug 4, 2005
    3,347
    103
    Stockport
    +231
    If you can't connect to games then there's definately something wrong.
    Anything on your firewall logs?
  7. reddevil63
    reddevil63
    Apr 12, 2005
    5,538
    +851
    Eureka!!!!
    Problem solved, resetted my router back to factory settings, restarted the computer, plug ethernet cable into 360 and went on Live, turned off 360, took cable out and stuck into PS3, started PS3 and put Motorstorm in and hit online and BOBS YOUR UNCLE. Its working!!!!
    Hate when something like this doesn't work, pull hair out time and then it always something simple that solves the problem which you don't think off at first. :D
  8. breadmaker6
    breadmaker6
    Apr 28, 2006
    2,929
    The Land Of The Concrete Cows
    +735
    1st rule of IT Management.....Switch it off
    2nd rule of IT Management....Switch it on again
    :D
