ps3 wont recognise all of my fat32 partations
electrosmith
I formated my 120GB external HD into 4 fat32 partations, but my PS3 will only recognise 1 of them, any idea what could be causing this.
payasyoutext
With FAT32 you can only have a max volume size of <32MB... So for your 120GB drive you will have to create 37, 32MB partitions.... If my math is correct... give or take a few MB.
I always create my FAT32 part for the PS3 at 30MB to be on the safe side
Hope that helps
Monkeypony
My 1tb external drive formatted to fat32 very nicely on 1 partition using fat32format.exe. (ps3 recognises all 1tb of storage space)
Takes all of about 3 seconds to do too.
Why would you want more than 1 partition?​
Uridium
Hope that helps
your post couldn't be anymore wrong I'm afraid.
the 32MB your refer to is actually 32Gb and it's not a limit on FAT32 partition sizes it's a limit of the GUI formatting tool in Windows.
There are 3rd party tools available (such as ridgecrops fat32format) that will format partitions up to 2TB
To answer the OP i beleive the PS3 will only read a single partition on each attached device.
andy1249
It can only recognise one partition , its does not have a fully featured OS and cant see more than one partition per USB connection.
Also I have a 160 GB WD passprt drive and it has no problem recognising the whole volume , also a 500GB WD mybook drive and it has no problem with that either , besides the fact that its a little on the slow side in picking up all the files.
Not unusably slow though.
james.miller
Dont you have to use DOS for that ?
nope. the 32gb limit is purely a windows OS lformatting limitation, but there are programs freely available (like that posted above) that will format a single fat32 partition to the maximum of 2tb:)
electrosmith
I'm trying out Fat32Formatter but I'm stuck. I've followed the instructions to the point where it says to type in "fat32format f:" in Fat32format's menu screen in DOS. But it keeps on coming up with
"Fat32Format" is not recognized as an internal or external command, operable program or batch file."
Any idea where I am going wrong ?
cols
Where did you save the fat32format.exe tool to?
You need to open up a command prompt and change directory to wherever you saved the tool to.
You then type the command in and it'll format it. :smashin:
sunnysunnysunny
Bingo. Basically, if you saved it to your Program Files folder, then using the command "cd" in command prompt, you would type:
cd C:\Program Files
Then after that you would type:
fat32format f:
f being your drive :smashin:
electrosmith
Tried the above and moved the Fat32format programe to my Programes folder, it still comes back with saying
electrosmith
This is what I typed in Command prompt while fat32format is placed in my Program Folder.
cd C:\Program Files\fat32format
with it then coming up with this
cols
Change directory to c/program files, not c/program files/fat32format...
Then, when it shows you're in c/program files, type in fat32format <drive letter>.
I've probably got the syntax wrong - follow the ridgecrop guide on how exactly to type the commands. :smashin:
electrosmith
Sorry I didn't understand that, is there not another programe I can use ?
sunnysunnysunny
Still says the same message. Surly something else exists out there ?
Not any freeware, this is your best bet.
If you want, I can make you a batch file that you run and it will do it all for you.
Just tell me what the drive letter is of your drive you want to format, and the path of where fat32format.exe is saved. :smashin:
clc.sheff
I have absolutely no Idea what the bloody hell any of you lot are talking about???? :confused:
I dread the day I need to put a new hard disc in my ps3 :D
