kosovosteve
Hi Chaps,
I'm having a bit of a problem with my PS3 connecting to my Netgear Router.
It seems there is no connection problems when the security settings (WPA) are turned off but it just will not connect when the passkey is required.
My Macbook will connect to it with no issues at all and the PS3 did connect when I first set it up.
Not sure if there is some form of fault present or if some settings have been changed.
Any help/ideas will be much appreciated.
Steve
Steve
