PS3 Virus
Discussion in 'Playstation Forums' started by verdoux, Feb 11, 2009.
  1. verdoux
    verdoux
    Jan 14, 2009
    29
    Hi all,
    So there I was last night on the internet via the PS3. All was fine until it flashed up saying that a virus had infected my system and that my data would be affected. I of course panicked, closed the browser down and since then I have been turning it on and off infrequently to see if there are signs of problems of which, so far, there are not.
    Has any one else come across any thing similar and if so what did you do?
    If not any advice would be great.
    Cheers.
  2. russd1978
    russd1978
    Aug 21, 2006
    1,784
    Maidstone
    +122
    What message came up exactly? Was it a web page or a system notification? It could have been one of those websites where they try and get you to buy their "anti-virus" program by lying to you.
    A virus would have to be specificially written for the PS3 (since most are targeted at MS Windows).
  3. verdoux
    verdoux
    Jan 14, 2009
    29
    It was a system notification and I'm sorry but I can't remember the exact message.
  4. verdoux
    verdoux
    Jan 14, 2009
    29
    Although saying that it did come up with web page notification to begin with.
  5. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    My Money is on this just being one of those annoying web popups "You have a virus, click here to scan" (then buy our software)
  6. Workshed
    Workshed
    Jan 28, 2007
    1,653
    Radstock, Bath
    +146
    It's nothing to worry about, it is not currently (and nor is it ever likely to be) possible to get a virus on your PS3. It's just a web scam thing, if you'd been on a Windows PC it would have come up in a Windows dialog box, it's just a javascript command.
  7. verdoux
    verdoux
    Jan 14, 2009
    29
    Thank you guys. Like I said I've been checking throughout the day and it appears ok.
    Cheers loads.
  8. Ed the Penguin
    Ed the Penguin
    Jan 14, 2008
    1,195
    Rugby, Warwickshire
    +142
    It may be worth checking the history on the web browser to see if the error message was a web page or not (if that makes sense).
  9. Workshed
    Workshed
    Jan 28, 2007
    1,653
    Radstock, Bath
    +146
    The message itself was most likely a javascript command and not an individual popup and so will not show up in the history however if you were to go back to the page it occured on you should see it again.
