PS3 video output help please
beerglass007
Found a web site doing 60gig JAP ps3 for £460 delivered to the UK
Quick question on the PS3
I have a plasma with RGB,component inputs. I under the PS3 60 gig version has HDMI output.
My plasma will take HD inputs and it works with the XBOX 360 via the component cable.
How can I connect the PS3 up so that I can use the HD video? From what I have been reading you could get a HDMI > DVI converter but the DVI needs to support HDCP.
I dont have a DVI input only component. Does this mean my plasma is gonna be no good for Blue-ray discs or even PS3 games. UK or JAP models.?
Many Thanks
:lease:
H
hey69
you can use a component cable on yoru ps3 . and use a component switchbox to switch between xbox and psx
Indiana Jones
Just get yourself a PS2/PS3 Component Cable and a Component Switcher and you will be all set.
Indiana Jones
You can indeed.
H
hey69
hi i bought a component cable from ebay (germany) for 10 euro, and that guy had also comp boxes for 15 euro. but i dont know if quality is great or not. i will search the sellers name
http://sintech.hitech.cz/
Indiana Jones
