PS3 to Monitor.
Discussion in 'Playstation Forums' started by horse39, Feb 1, 2009.
  1. horse39
    horse39
    Jul 25, 2007
    33
    Hi Folks,
    Doing a bit of tidying up after Christmas, and decided to put the PS3 into one of the kids bedrooms and have it connected to a dell Monitor. I'm not having much success with this and tried a few variations' any ideas?
    Regards,
    Horse.
  2. sykotik
    sykotik
    Sep 8, 2008
    7,098
    co. durham
    +2,269
    yip! your going to need a hdmi-dvi cable .something like this
    HDMI to DVI Cables
    the only down side. is that your not able to get sound from this type of cable ...
    so your going to need an amp with some speakers. to here sound
    or even a hi-fi with an optical input will do!
    andrew
  3. vib ribbon
    vib ribbon
    Nov 21, 2006
    1,048
    Sutton Coldfield
    +116
    You need to make sure the DVI port on the monitor (if it has one) supports HDCP. I tried my PS3 with a 19in LCD Dell Monitor i had but into didn't work due to the port not being HDCP compatible. :thumbsdow
    Make sure it is before you splash out on a cable. :lesson:
  4. Coffin
    Coffin
    Mar 20, 2008
    11,576
    +5,184
    So you've already attempted this, if so with what type of cable(s)? What's the problem you are having?
  5. _Sion
    _Sion
    Sep 26, 2006
    701
    43
    Newcastle upon Tyne
    +118
    I ran my PS3 through a HDMI-DVI cable for a while, a lot of devices with a DVI socket also have a 3.5mm socket for DVI audio in, you just need a 2-phono to 3.5mm male adapter and connect up multi-connector cable's red and white connectors to the adaptor.
  6. AnotherDude
    AnotherDude
    Apr 14, 2008
    5,860
    83
    Around this place we call the UK
    +236
    so how would you go about finding out if your monitor supports HDCP?
  7. Jamie Smith
    Jamie Smith
    Jan 30, 2009
    Leeds, England
    Looks up the spec of your monitor online is the easiest way I would guess. Or contact the manufacturer.
  8. trent steel
    trent steel
    Dec 21, 2004
    3,406
    West Yorkshire
    +766
    You could use an HDfury or HD fury gamer edition lead which plugs into the vga port of your monitor and offers full 1080p with no problems with HDCP :smashin:
  9. horse39
    horse39
    Jul 25, 2007
    33
    Hi Folks,
    I tried it on the kids Dell Monitor which has DVI and also on my own monitor which is 6 months old and has an hdmi input but had no luck with each unit. But still when I connect it to the television it works fine.
  10. Hurin
    Hurin
    Jul 20, 2008
    87
    +13
    Maybe the resolution is set too high for the monitor, it may be that your ps3 is set to 1080p and your monitor only supports 720p. Once you have plugged the ps3 into the monitor have you tried holding the ps3 on switch (touch panel) down for about 5 seconds till you hear several beeps? This will reset the display mode.
  11. Jamie Smith
    Jamie Smith
    Jan 30, 2009
    Leeds, England
    That is good advice, I'll remember that if I ever get stuck. :clap:
  12. horse39
    horse39
    Jul 25, 2007
    33
    Thanks, Hurin - that seems to have done the trick
    Horse.
