PS3 Stopping colours for calibration. Any ideas?
Discussion in 'Playstation Forums' started by fredted40x, Nov 27, 2010.
  1. fredted40x
    fredted40x
    May 29, 2007
    165
    +8
    I'm just trying to calibrate my projector to use with the PS3 but something on the PS3 is stopping the black level adjustment image from displaying the darker blacks.
    If i turn the brightness all the way up i can see the same flashing black bars as i could with it turned down.
    Any ideas what could be stopping it?
  2. custard10
    custard10
    Jul 24, 2007
    1,341
    83
    walsall
    +376
    set bd/dvd output in ps3 to ycbcr.
    and then switch on superwhite in ps3 to reveal WTW and BTB detail.
    if you trying to calibrate using files stored on the ps3 or streamed to it, this will not work. reason being that the ps3 will only reveal 16-235 info for rgb which is the only way the ps3 can output the files.
  3. fredted40x
    fredted40x
    May 29, 2007
    165
    +8
    still no luck :(.
    Its using a dvd so should be fine.
