ps3 stopped working via projector
Discussion in 'Playstation Forums' started by BilboBaggins, Feb 4, 2014.
  1. BilboBaggins
    BilboBaggins
    Dec 2, 2005
    36
    +3
    Setup
    Ps3 Slim> 0.5m hdmi cable - Onkyo 606 > 20m hdmi cable - Neet Signal Booster - 0.5m hdmi -Projector
    The above worked fine for a few months then it stopped working. Just cannot get the pic to display. All I hear is a loud static noise from projector, picture flickers a lot. The noise is so annoying that you have to switch the thing off.
    Tests
    Connected ps3 direct to projector using same 20m hdmi = No difference, same signal breakup/noise
    Connected ps3 using short hdmi cable to projector and it works
    Connected ps3 to tv, and it works fine
    Connected fat ps3 over 20m hdmi and it works
    Sky works over 20m hdmi to projector
    Wii U works over 20m hdmi to projector
    No idea what to do. I had to get the signal booster originally as ps3 just wouldn't work but everything else did. Now Ive attached a power supply to the booster, and still no luck. Ive ran it without power supply for a few months previously.
    Can anyone advise what to do......
    Thanks in advance
