I've finally solved my PS3 problem running the surround sound through my Phillips TV to my Philips DVD home theater system. My question is it only stops clicking when i set it at 2ch 44.1khz and 2ch 48khz. I still get 5.1 surround sound is this correct?
was hoping someone could confrim that when its set on 2ch pcm it does output a 5.1 signal.
If the PS3 is set to 2ch audio then thats all you'll get: 2.1 sound
Hasn't MichaelGL already answered that :-
If I set it to only output through HDMI 2ch 44.1khz then why does the thx test confirm 5.1 and every speaker work.
Like the others said, if it is set to output 2ch sound, that's all you'll get - stereo (2.0 rather than 2.1 I think as I don't think that includes a LFE track).
How are you connecting your PS3 to your sound system? Optical or HDMI? If you are using optical, you have to set the sound output to bitstream to get surround sound. HDMI can be as 5.1 or 7.1 LPCM or bitstream.
Doesn't make sence as if it was stereo why would the receiver state its getting either a dts signal or Dolby Digital and have full surround sound on the thx test and seemingly in films. Sony don't half screw things up.
Sorry, what have Sony done?
Ok the problem is that it's set at 2ch pcm but when I do the surround sound thx test on monsters inc dvd the sound outputted is 5.1 as all the speakers respond.
Its a philips hts 3357. It confirms it's recieving a DTS signal so I'm just confused was hoping someone could confrim that when its set on 2ch pcm it does output a 5.1 signal.
I'm not certain about Monsters Inc, but DTS can be 2-ch PCM. Most likely, as stated before, the two-ch signal is being matrix'd into Dolby Pro Logic, or other derived 5.1 format.
Ok that explains it. So it is 5.1 surround sound then? Jobs a good un! Now to find out why music won't come out.......
