PS3 sound problem
Ryuzaki
Hello everyone I'm new & just wondered if anyone could help me? I've got a sound problem with my PS3. Basically the sound keeps cutting out every couple of minutes now & again. It only dissipears for a second or so but it's really frustrating. I've tried different blu-rays & the problems still occur. Originally I thought it was something to do with the Hdmi lead as I was only using that to hook it up to my plasma tv. But today I have also tried to hook it up to my other plasma tv & amplifier this time using an optical cable but the sound still vanishes. Has anyone experienced the same problem? I have tried different hdmi cables so I certain there not causing the problem which makes me think its the PS3 itself. Any help would be great! Thanks :suicide:
kingfats
Hi Ryuzaki. :)
If you've tried another lead and connected to different kit,then really :( you can only presume it's the PS3 at fault.Does it still do this direct to the TV. :confused:
Still under warranty?
All the best.
Ryuzaki
Thanks Kingfats but its seems to be working again now. Yesterday I did a system update & it gave me more linear pcm audio options so I added them on & it seemed to have helped! I'm so happy again, now I can carry on watching Smallville! :smashin:
But does anyone know if this is usually the cause for soundloss? Like would the sound mess up ocassionally if the latest update has not been installed?
kingfats
Hi Ryuzaki. :)
Not sure what your problem was :confused: the main thing :D it's fixed.............be happy! :)
Glad your sorted and all the best.
