ps3 slim how to get game out?
Mr Noble
Just went to power on the ps3 and it won't turn on , checked the fuse and it's fine.
Going to take it back to shop tomorrow but my mw3 disc is still in it (not purchased from same store)
Is there a way to remove the disc without causing any damage to the console/disc?
It's only 2 months old I'm gutted :mad:
RottenFox
There's a screw, that will let you release the disc, but if they won't swap it, it's a pain in the rear to get it set to where it was, so don't try it unless you are guaranteed a swap.
http://www.blogcdn.com/www.engadget.com/media/2009/08/ps3-slim-unboxing2-dsc_0048-rm-eng.jpg
See the hole next to the blue screw, you need a small cross headed driver to slip in there, turning it anti-clockwise, to "unwind" the drive, but once done, the drive will be broken, unless you can manage to get it back to where it was, and I mean exactly where it was.
Podcast: Large Screen HDR TV or Projector For Home Cinema + Best of the Month
