PS3 reset itself, What Happened !!!
Discussion in 'Playstation Forums' started by zapata, Feb 4, 2009.
  1. zapata
    zapata
    Jan 7, 2004
    616
    Camberley
    +17
    Folks, last night for some unknown reason my PS3 decided to rest itself, all the sound/video settings had gone and also my wallpaper. I had to do all of the setup again, anyone know what may have happened. The unit is hard wired to the internet, could anything from the net have done it.
  2. Tuskenraider
    Tuskenraider
    Dec 19, 2008
    15
    Staines
    That happend to me aswell everything worked fine after i put all the settings back i have mine set using wireless
  3. DaddyDee
    DaddyDee
    Feb 10, 2003
    1,425
    Waddington
    +89
    Doesn't it do that if you turn off the PS3, but keep your finger on the on/off button a bit to long. Is it some sort of reset feature, maybe someone more techy knows what I'm on about?
  4. zapata
    zapata
    Jan 7, 2004
    616
    Camberley
    +17
    It's really strange because I watched an episode of Band of Brothers at 6pm then switched off, went back to it at 9pm and all the settings where reset.
  5. Tuskenraider
    Tuskenraider
    Dec 19, 2008
    15
    Staines
    i dont think i held the on/off button down to long to reset it but it happened a while ago and its been fine since wouldnt worry about it
  6. Jamie Smith
    Jamie Smith
    Jan 30, 2009
    Leeds, England
    I think it is quite worrying that your ps3 would do that. :confused:
  7. zapata
    zapata
    Jan 7, 2004
    616
    Camberley
    +17
    It's never done it before and I have had it over a year. The only thing I have done recently is update the firmware to 2.60
  8. Tuskenraider
    Tuskenraider
    Dec 19, 2008
    15
    Staines
    it happend months ago and i havent had any problems since
