Hi there,
I recently aquired a new 40Gb PS3, but am having troubles getting the damn thing online. My problem, like a lot of others, is the dreaded NAT type 3. I want to connect my PS3 to my PC to use its wireless connection via ICS. My PC uses a stronger aerial and has 100% signal strength compared to the 60% that my PS3 quotes using its built in wireless so I want to use my PC's connection for obvious reasons.
Using ICS and running the PS3 connection test I always seem to have a 1 in 3 chance of getting a NAT type 3 which obviously isnt ideal, I have opened all needed ports from my router and also on Windows firewall. UPnP is never available using ICS although it is available if I bridge the connection instead of ICS but still occasionally get a NAT type 3.
Does anyone know any solutions to this problem? Or does anyone succesfully use ICS and PS3 together with a constant NAT type 2? What equipment do you use?
My equipment is as follows:
Netgear WPN824 wireless router.
Netgear WPN311 PCI wireless card.
Windows XP Professional.
Virgin 20mb cable.
Virgin 20mb cable.
