PS3 no picture after cable change
Status
Not open for further replies.
Agrav8er
Had to send our LCD back to the shop for repair:mad: so have had to reinstate our CRT in the front room.
Problem is that have connected the PS3 with the supplied cable (which worked previously) and cannot get a picture. (Was connected to the LCD HDMI to HDMI) Have tried turning PS3 off and back on again several times to see if it defaults to basic set up but still no picture (or sound if that matters)
Any ideas please??
Thanks!
t1m103
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Agrav8er
Result!! t1m103 you should be writing the Sony manual, why could they not be that clear!:confused:
Status
