PS3 media server dlna error 7531
Discussion in 'Playstation Forums' started by covdav, Mar 20, 2011.
  1. covdav
    covdav
    Mar 20, 2011
    3
    I have ps3 media server and a macbook pro with a sky netgear router. Everytime i try to connect the 2 i get the above error. It works seamlessly if i use a wired ethernet connection. My mac also works fine on another ps3 and router (friends).
    So the issue is between the Router and ps3.
    Is there anyone out there with an answer? as all other google searches and forums lead to dead ends!!
  2. themediaman
    themediaman
    Nov 17, 2010
    2,007
    Glasgow
    +171
    Can the PS3 actually see the PS3 Media Server Icon..............?
  3. covdav
    covdav
    Mar 20, 2011
    3
    Yes, It can see it, but when you select it, it says no files and keeps flashing the above error message.
  4. themediaman
    themediaman
    Nov 17, 2010
    2,007
    Glasgow
    +171
    Try changing wireless channels, 1,6 or 11 I think the best ones are, in case of interference with other wireless signals.........
    You could also try assigning the PS3 with/or another static IP address and prioritizing it within the router.......
  5. mikerowney
    mikerowney
    Mar 29, 2011
    I have had numerous DLNA protocol and network errors when streaming video and mp3's through my PS3 media server. I switched off my baby monitor and the problems have immediately gone away.
  6. themediaman
    themediaman
    Nov 17, 2010
    2,007
    Glasgow
    +171
    LOL, that is comical, you should maybe try changing the channel of your wireless on the router, I think 11 is the highest it goes and a good place to start, means both devices could operate at the same time.........
