just behind mine in the queue!
And both behind mine i'm afraid
So in the FAQ it says turn off all PCM so the amp can handle it rather than the PS3. So do I go to SOUND SETTINGS in the XMB, and then rather than AUTO, just do manual and select everything except the LPCM options?
Using Onkyo HTX-22HD btw.
Thanks for the guide Br0ken, amazing stuff. Also just bought your itrophies, but cannot download it until home as too big for 3g network :smashin
Could also do with some help myself.
Will this also benefit blu-rays, DVD's & games?
Thanks for the support buying itrophies, don't forget to rate and review it
As has been mentioned, the guide is kinda outdated, especially the media type support and sound. I was hoping another keen avf member would take over and update it, I really don't have the time to do it anymore sadly.
Well I would do part of it, probably with Uridium, but I don't think we have the necessary permissions...
How come, were you naughty ?!
hi chaps, not sure if this should be posted here or not, but i have a basic question regarding the video folders on the ps3. is it possible to make your own folders or are the only ones you can use the ps3 generated month ones?
thanks in advance.
I'm pretty sure, with videos you have transferred over to the PS3, you can rename the folders that they're stored in..
Hi - great information, thanks!
just to chip something in useful here:
If you have an MKV with and AC3 stream, you can convert this for PS3 playback very quickly using tsMuxer (SmartLabs tsMuxeR)
Just add a file into the input queue and select m2ts muxing and hit start. It'll convert a 4 gig file in a couple of minutes & the PS3 plays it back with full DD 5.1 sound output too.
So how do you actually play iplayer through a PS3, simply in a browser window. If so, can one play the HD content too
