PS3 - Headset Blues?
Discussion in 'Playstation Forums' started by Weggie, Apr 28, 2007.
  1. Weggie
    Weggie
    Jun 1, 2003
    2,933
    68
    +96
    I have just purchased the Sony DR-BT20NX to use with my PS3. I have successfully paired it with the PS3 (and it shows the correct model number) but I do not get any sound.
    How do I set-it up so I can listen through the ear phones and use the mic?
    Anyone...
    :smashin:
  2. breadmaker6
    breadmaker6
    Apr 28, 2006
    2,929
    The Land Of The Concrete Cows
    +735
    On the set up..did you test it to see if you are getting the 'blips' of it recognising you talking?
    If not it isn't connected properly.
    If you do, have you set up the input and output to your headset?
    For help go to this link.
  3. jonhuz
    jonhuz
    Mar 3, 2006
    304
    +19
    Hey, just setup my sony iv835 (or something). Need to go into audio settings, then change the input/output to your headset model number. If it's working the mic bar should riase when you speak into it.
    Haven't been able to check mine in motorstorm. No one seems to chat even in the headset named games. Anyone know if you have to press a button to chat?
  4. breadmaker6
    breadmaker6
    Apr 28, 2006
    2,929
    +735
    Yes, L3.
  5. Weggie
    Weggie
    Jun 1, 2003
    2,933
    68
    +96
    Yes, the top bar varies depending on how much sound is going in from nothing to yellow, green and red.
    I have input and output set to the Sony but when I play trailers, etc, I do not hear anything.
    I primarily want it so I can watch and play things through the headphones and not disturb any one else.
  6. breadmaker6
    breadmaker6
    Apr 28, 2006
    2,929
    +735
    ahhh...in a word NO.
    The device is set up for chat and ingame chat only.
  7. Weggie
    Weggie
    Jun 1, 2003
    2,933
    68
    +96
    Damn, wasted my money then as I wanted to use it to watch films, etc. without disturbing any one. Seems a wasted opportunity for Sony!
  8. RSVdaz
    RSVdaz
    Mar 26, 2007
    1,500
    +49
    can you not use head phones from your telly?
    you can get wired on non wired..as stated above..the headsets are for in game chat
  9. Weggie
    Weggie
    Jun 1, 2003
    2,933
    68
    +96
    It's a nice suggestion, but my TV is DVI. I would have to do it through my amp.
    Hopefully, maybe Sony will update the facilities especially as it is supposed to be more than a console.
