Ps3 / Hdmi
Discussion in 'Playstation Forums' started by aballah, May 2, 2007.
  1. aballah
    aballah
    Jul 28, 2005
    10
    Hi there, I'm having problems connecting my PS3 to my Panasonic plasma (TH50PHD8)
    using an HDMI cable. The PS3 work fine using the AV lead supplied in the box, but obviously not at full picture quality, so I wanted to switch to HDMI input.
    I've tried changing the output lead option to 'HDMI' using the PS3's on-screen settings menu
    but can only access this with the machine connected using the AV component lead. When I select 'HDMI', it checks but doesn't recognise the option.
    I have tried another hdmi leads made no different
    PS3 works fine with my Sony VPL-HS60 Projector connected via HDMI
    I have done as it says in the ps3 manual
    http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
    Help!! Anyone got any bright ideas? Am I missing something very obvious?!
    Any suggestions gratefully received!
  2. winstano
    winstano
    Apr 4, 2007
    2,402
    63
    +213
    One solution could be to connect with the HDMI cable only, and hold the power button for about 5 or 6 seconds, until you hear 2 beeps... That'll then look for any output by default, which should then be hdmi :)
  3. aballah
    aballah
    Jul 28, 2005
    10
    Thank you, for replying but still no joy
  4. geomuss
    geomuss
    Jul 10, 2006
    2,041
    musselburgh
    +158
    does everything else work ok on the HDMI socket you are trying on the plasma?
  5. aballah
    aballah
    Jul 28, 2005
    10
    MY PC work's fine when its connected to HDMI port, so i dont have an issue with my HDMI port
