PS3 HDMI Audio & Video
Discussion in 'AV Receivers & Amplifiers' started by S3rv3d, Aug 30, 2007.
  1. S3rv3d
    S3rv3d
    Jun 3, 2005
    1,026
    83
    +268
    I will be gettin my back tommorrow from Pioneer following a firmware update. However before it went away i couldnt get 1080p/24 to passthrough with it. Its a VSX-AX2AS. The screen kept going blank every 3 seconds or so. However 24fps can now be set to on instead of automatic, would it work? I have a Pio 436XDE so it only supports 1080p/24.
    If this didnt work i want to try and take advantage of the 24fps and LPCM audio. Is there anyway I could do this by splitting audio and video but only using hdmi? And could it be configured?
    Justin
  2. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    I've moved it for you. Hopefully you will have more luck here.
  3. S3rv3d
    S3rv3d
    Jun 3, 2005
    1,026
    83
    +268
    Bump,
