PS3 Hard Disk Upgrade Limit
Discussion in 'Playstation Forums' started by max999, Sep 5, 2007.
  1. max999
    max999
    Jan 11, 2007
    64
    Does anybody know if there is a Gb limit to the size of 2.5" hard disk that can be used to replace the existing?
    Also, I see that 2.5" HDDs come in several different formfactors ie: 1/8 1/6 etc. which is compatible?
    thanks
  2. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
  3. PygoShlee
    PygoShlee
    Feb 2, 2007
    2,306
    +155
    Yeah I think aslong as it's 2.5" 5400rpm SATA then you can use it.
    Mine's a 120gb, I've half filled it up (got 68gb left) and thats with about 12 demos on it, and about 20 odd videos, and a good GB of music!
    Ash
  4. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    highest ive used is a 500gb 3.5". highest you can use? current its 1tb ;)
  5. andrewrunagall
    andrewrunagall
    Sep 4, 2005
    1,162
    Hadleigh, Essex
    +63
    I take it that's external.
  6. Darth_terra
    Darth_terra
    Jan 13, 2006
    5,117
    UK
    +956
    Yeah that would be external you cant get internal 2.5" sata drives at that capacity yet..
    to answer the OP's question your only limited by what size drives are available ie as long as it's 2.5" 5400rpm SATA you can use it.
  7. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    external drive on an adaptor. it acts as the internal drive. well, it *is* the internal drive, just external...lol. so im not limited by space, rotational speed or price :)
  8. Darth_terra
    Darth_terra
    Jan 13, 2006
    5,117
    UK
    +956
    That makes sense :D
  9. onkeh
    onkeh
    May 15, 2006
    2,441
    83
    London
    +369
    Can't look pretty, though..
  10. Mickus
    Mickus
    Jul 11, 2005
    3,071
    South East Kent
    +332
    I'm considering upgrading my HDD soon. Can anyone who has previously done this confirm that when you run the backup prior to upgrading, some data won't get backed up. If so, what data won't get backed up?
  11. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    [​IMG]
  12. psikey
    psikey
    Oct 5, 2005
    7,839
    3
    South Yorkshire
    +1,048
    Looks very neat to me :smashin:
    Where did you get the case & adapter?
  13. Mr THX
    Mr THX
    Nov 26, 2002
    1,309
    Barnsley
    +32
    Looks fine from here too.....
    I'm going for a 500Gb Western Dig Book type HD i think. Small enough to sit round the back of the PS3 in the AV rack. :thumbsup:
  14. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
  15. Stringent
    Stringent
    You can use a 7200rpm one as well if you like. I doubt you would see much performance increase over it though.
  16. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
    Yep you can.
  17. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
  18. micks_address
    micks_address
    Nov 29, 2001
    4,671
    83
    Dublin
    +239
  19. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
    Yep it should work! ;)
  20. nbkicker33
    nbkicker33
    Aug 13, 2005
    1,287
    48
    +64
    do you need to backup data from old drive in ps3 to new hard drive, or can u just take old drive out, put new one in, then let ps3 format it and set it up, then just download all files onto it again??, looking to get a 160gb hard drive for my ps3, but not ordered a sata to usb convertor to connect drive upto ps3 first to copy files.
  21. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
    What stuff have you got on your PS3?
  22. micks_address
    micks_address
    Nov 29, 2001
    4,671
    83
    Dublin
    +239
    Well i got the harddrive yesterday and borrowed a mates external drive to do the backup/restore.. longest part was backing up, took about 1.5 hours to backup 43gb onto disk.. the upgrade took less than ten minutes and then another 1.5 hours to restore everything.. everything worked great.. nice of Sony to make upgrading so easy :)
    should have lots of room now for music/video and games..
    Cheers,
    Mick
    Originally Posted by micks_address
    guys i should probably just search but can i ask would this drive be suitable for my ps3?
    Samsung SpinPoint M5 250GB 5400RPM SATA 2,5"
    http://www.komplett.ie/k/ki.aspx?sku=336007
    Cheers,
    Mick
  23. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
    I did not have a external Hard Drive had to move my game saves to my 4GB PSP memory card (5 mins) then put my new one in (10 mins) then download all the stuff agin (4-5 days) ! :suicide:
    Now that it's in i have lot's of space! :D
    PS: Changed mine ages ago!
    Hard Drive: Western Digital Scorpio 250GB S150 5400RPM 8MB
    http://www.dabs.com/productview.asp...1&NavigationKey=11154,47250000,40970000,50473
    Was £117 :suicide: when i got it now £106.51 delivered! :thumbsup:
