groovytunes
Sorry if this issue has been addressed before, but i did not find an answer in forums. A week ago I disconnected my ps3 from my hdtv, and connected to my 3dtv to test the 3d capabilities. I was considering buying a second ps3 system with $210 best buy rewards I have saved. It worked just fine. I reconnected the ps3 to the hdtv it was originally on via the hdmi cable. Now only half the in game sound can be heard. I switched to another hdmi cable, the sound seems to work but half of it is extremely low volume. I checked the settings, searched youtube and the net for answers but cannot find a solution. It seems to me maybe the hdmi connection in the ps3 was damaged somehow when I disconnecteed or re-connected the cable. Does anyone have any ideas or had this issue, or have a fix?
Thanks..
I want to note that I had no prior issues with this ps3 or hdtv.
