After having recently pucharsed a UK PAL Playstation 3, I am discovering a problem with Blu Ray films.
I only have 3 but it is happening with two of them whereas SD DVD playback is fine.
The two in question are a US edition of Superman Returns and a UK edition of Casino Royale.
They are being fed via HDMI to a 1080p projector.
Basically the issue is a green/blue/pink (green being the strongest colour visible) interference line that occurs about 6 times during the film. It will appear near the centre of the image although this is variable. It's on for a second and is literally a line... the only thing I can describe it as is as if I am fiddling about with the cables at the back and it is causing static on the image.
Is this a known issue?
Thanking you
Thanking you
