PS3 Fan Test
Discussion in 'Playstation Forums' started by Usama, Jun 11, 2008.
  1. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
  2. moriartygm
    moriartygm
    Feb 1, 2006
    302
    Ipswich
    +51
    I have just done his, and it certainly works, how much good it does, I don't know, but the fan sounds a little quieter now.
  3. kingbal
    kingbal
    Nov 30, 2006
    1,320
    48
    +55
    saw this earlier inthe fan noise thread,someone mentioned there was a way to do it on a 60gb one but nobody mentioned how!
    Anyway, is it just me thats not that bothered about dust? I'll give all my kit a wipe now and again to get rid of dust but blowing it out with a fan and using hoovers to suck the air out:confused: I suppose its fair enough if its gonna extend the life of your equipment(does it?) but i think some people are just a bit too anal! :D
  4. coluigi
    coluigi
    Jan 9, 2007
    1,290
    Manchester
    +86
    It's a trick!
    This topic was discussed a couple of months ago.
    Re: 60gb PS3 fan test, some genius realised if you turn your PS3 on and turn it upside down the fans will ramp up very quickly - mostly because it's overheating...
  5. LooJ
    LooJ
    what do you mean its a trick? how is it tricking you? :confused:
  6. kingbal
    kingbal
    Nov 30, 2006
    1,320
    48
    +55
    trick of the trade!
  7. coluigi
    coluigi
    Jan 9, 2007
    1,290
    Manchester
    +86
    With the 60gb one, a guy said you could do a fan test by turning your PS3 upside down. All this was actually doing was trapping the heat and overheating your PS3. The guy even said 'it might say your PS3 is overheating - but its not'.
    Hence, a trick.
    The 40gb version is legit though.
  8. LooJ*
    LooJ*
    Jun 12, 2008
    ok, i see. i thought u meant the 40gb one was a trick
  9. medicmanonet
    medicmanonet
    Apr 12, 2007
    254
    Cwmbran
    +18
    :smashin:
    Nice to know...
    I assume it might 'cough' be a really really good idea to remove the PS3 from the cabinet first before trying this and maybe try and catch all that dust!
    Warning
    'Not for the Asmatics amoungst us me thinks'
