Ps3 Display settings :s
Discussion in 'Playstation Forums' started by rchads89, Feb 2, 2009.
  1. rchads89
    rchads89
    Nov 30, 2008
    4,774
    +269
    I have a brand new ps3 80GB now swapped it for my xbox 360 i see on ps3 they is LOADS of display settings. I have a 37''LG5000 Full HD 1080p set, 50,000 contrast ratio 5ms response time. Now they is so many settings like RGB setting limited or full on / off ??? Then.... Super-White HDMI on / off ??? Cross Color Reduction Filter on / off ???? Could anyone please advice me on what to set this too.
    Thanks alot. :thumbsup:
  2. rchads89
    rchads89
    Nov 30, 2008
    4,774
    +269
    Anyone?
  3. runas
    runas
    Jun 11, 2007
    238
    28
    +28
    Why not ask the question in the LCD TV forum. They frequently have threads about TV setups for all types of inputs.
    runas
  4. cols
    cols
    Sep 5, 2008
    3,338
    Colchester
    +517
    Well it depends on the tv and set up etc what the best settings are - it's best imho to google each setting and learn about it. You find quite a lot out that way!
    I'll tell you how i have mine and why-
    rgb full range: set to "limited", because set to "full" crushes the blacks and causes loss of detail in dark areas - different shades of black all just become one black lump.
    Cross colour reduction filter: ignore this, it only applies if you're using composite (yellow plug on av multi cable)
    y/pb/cr super white: on, i don't fully understand it, something to do with all video content being encoded in y/pb/cr thing, this only works if below setting is done i think
    bd/dvd video output format (hdmi): set to y/pb/cr, i'm no expert in this and my memory is patchy at best, but iirc it's something like games will output in rgb anyway, this setting is for blu ray and dvd. It was explained to me basically this should be set to y/pb/cr as that's how video content is encoded.
    That's how mine's set up anyway! :)
  5. cas398
    cas398
    Nov 25, 2007
    2,530
    Glasgow
    +184
    I found the online instruction manual on the PS3 rather helpful. It's quite descriptive for each setting, I pretty much got all the settings sorted and it didn't take long at all.
  6. kendoll
    kendoll
    Nov 28, 2005
    3,789
    Sydney
    +551
    The online manual can be found here. :smashin:
  7. mascot
    mascot
    Nov 28, 2005
    714
    46
    +177
    Does anyone have a link to a downloadable PDF version of this online manual? It would be handy to keep as a printed document for quick and easy reference.
  8. cas398
    cas398
    Nov 25, 2007
    2,530
    Glasgow
    +184
    Isn't it easier just to click the link on the PS3:confused:
  9. trent steel
    trent steel
    Dec 21, 2004
    3,406
    West Yorkshire
    +766
    It is dependent on your display. If you have RGB Full on into a display that doesn't support it... you'll get some major 'black crush' going on. That said there are RGB tests you can download to check if your display is capable of displaying below blacks and above whites
  10. mascot
    mascot
    Nov 28, 2005
    714
    46
    +177
    Not really - what can be easier than having a manual open in front of you, rather than clicking a browser on and off and waiting for pages to load, then flicking back to the xmb? Seems like a pain in the ass using the online guide, unless you have it open on a laptop next to you. And even then, it's still more of a pain in the ass than looking at a paper copy.
    I dunno. Maybe I'm just old-skool.
  11. Jamie Smith
    Jamie Smith
    Jan 30, 2009
    Leeds, England
    Where can you download these tests?
  12. cols
    cols
    Sep 5, 2008
    3,338
    Colchester
    +517
    Try these. With rgb set to full, if you can't make out any detail, then set it to limited. :smashin:
