PS3 BR menu keeps popping up
Discussion in 'Playstation Forums' started by bagatanmd, May 7, 2007.
  1. bagatanmd
    bagatanmd
    Oct 8, 2005
    1,486
    48
    +94
    hi guys,
    hava a little problem with my ps3. while playing BD, the pop-up menu that show when you press the triangle button, intermittently pops up while watching BD. haave to press triangle button again to make it disappear. any idea guys?
    andrew
  2. stu.artd
    stu.artd
    Jul 29, 2005
    3,895
    +333
    I was going to suggest a faulty controller, but if it was then surely the menu would be deactivated the same way that it's being activated ?
    Do you have more than one controller or the remote control ? If you do then switch them all off other than one of them and enable each in turn to see if the fault is isolated.
  3. BluntY
    BluntY
    Dec 6, 2006
    40
    Edinburgh
    It happens to me, I'm thinking it might be some blueotth interference.
  4. Jim_Fear
    Jim_Fear
    May 17, 2005
    1,801
    Caterham
    +59
    Remember, wireless phones, wireless networks and microwaves all emit on the 2.4GHz band :)
    I can't stand wireless, the sooner I can make everything in my house wired bar the laptop the better!
  5. williemaykit
    williemaykit
    Jan 8, 2006
    1,310
    Bromley
    +163
    That's what I put it down to as well - interference. Only happened once when I was watching Pursuit of Happyness the first time. I tried it again later that day and there was no problem. In the end, switched off the wireless on the Be Box aka Thomson SpeedTouch (have an Airport Extreme for wireless, using the 5GHz band) and the problem has permenantly gone.
  6. bagatanmd
    bagatanmd
    Oct 8, 2005
    1,486
    48
    +94
    thanks all for the reply guys.
