ps3 blu ray work on sanyo Z2 pj via hdmi-dvi?
Discussion in 'Playstation Forums' started by jamiev, Apr 28, 2007.
  1. jamiev
    jamiev
    Jan 4, 2004
    924
    +35
    hi, anyone confirm if the get a signal from ps3 blu ray with the z2 via hdmi-dvi?
    thanks
  2. Spiro25
    Spiro25
    May 18, 2006
    3
    Hi there, I can confirm that the PS3 works with the Z2 using hdmi to dvi. Picture looks great in both 720p and 1080i
  3. jamiev
    jamiev
    Jan 4, 2004
    924
    +35
    thanks very much, what length and make cable do you use?
    got a link?
    thanks again
    jamie
  4. BritanniaJaf
    BritanniaJaf
    Jul 12, 2004
    4,363
    Glasgow
    +324
  5. jamiev
    jamiev
    Jan 4, 2004
    924
    +35
    hi, thanks, so are you also using the z2 and ps3 together and getting 720p via hdmi-dvi, i presume?
    also wanted to ask which version of the ps3 is everyone using, ie; usa, uk, japan, hk etc...?
    thanks again
  6. BritanniaJaf
    BritanniaJaf
    Jul 12, 2004
    4,363
    Glasgow
    +324
    Yup can get 720p and 1080i through the Z2 with that cable and using a UK PS3
  7. jamiev
    jamiev
    Jan 4, 2004
    924
    +35
    ok, thanks , just bought a japan ps3.
    could you recommend any cables 10m in length?
    :cool:
  8. BritanniaJaf
    BritanniaJaf
    Jul 12, 2004
    4,363
    Glasgow
    +324
    Not sure m8, email that seller on ebay and see if he can help
  9. Tony Hoyle
    Tony Hoyle
    Aug 4, 2005
    3,347
    103
    Stockport
    +231
  10. jamiev
    jamiev
    Jan 4, 2004
    924
    +35
    anyone confirm if the ps3 is upscaling sd dvd on the z2 via hdmi-dvi?
    which region sd dvd's are you using?
    thanks
  11. jamiev
    jamiev
    Jan 4, 2004
    924
    +35
    it does work, thanks all.:thumbsup:
  12. teo1
    teo1
    i have that set-up.hdmi cable with dvi adaptor.it's perfect in 1080i.
  13. jamiev
    jamiev
    Jan 4, 2004
    924
    +35
    yeh, is good pq. whats the best setting for the ps3 upscaling? full screen?:lease:
  14. Tony Hoyle
    Tony Hoyle
    Aug 4, 2005
    3,347
    103
    Stockport
    +231
    Usually 'normal'. Full screen stretches 4:3 pictures (full screen is what they call stretchyvision in the US), which looks pretty bad on a PJ.
    OTOH there aren't any 4:3 blurays that I'm aware of so it wouldn't make a difference for most viewing.
  15. jamiev
    jamiev
    Jan 4, 2004
    924
    +35
    is there anyway the ps3 can upscale backed-up dvd's? ie dvd-r?
    thanks
