PS3 blu-ray on SD-CRT
I
iron_lifter
Im looking to get a PS3 for its many uses, but Im curious, I have a standard def CRT with componant input, would I be able to play a blu-ray movie allbeit in standard def? And if so, would it still look better than a DVD due to better encoding and much higher bitrate?
Thx!
dan1979
It would look a bit better for the reasons you stated, if you're renting then you might as well but it would be madness to pay double/triple/quadruple the DVD price or whatever the current premium is for it.
I
iron_lifter
I view it like.. When i do get a HDTV, then Il have myself a small collection to enjoy. Kinda makin myself future proof. id only ever get fiilms that i really liked in blu-ray. Eventualy I will get a HDTV.
Lewis123
As long as your current TV can accept a 60Hz signal youre fine :thumbsup:
I
iron_lifter
um...not 100% sure
Its a Toshiba 32ZD26P which allows me to play NTSC and even features NTSC progressive scan, would that be 60Hz?
I
iron_lifter
So guys, thx for the advice! May I ask you, what is it about blu-ray and 60Hz anyway? :confused:
Thx guys ;)
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
